d4 light flashing
hello,
I'm having trouble with my 94 Honda accord. I did the paperclip method on car and the d4 flashed these codes. 4, 7, 8, 14 and 1. please identify codes so I can get them fixed. thank you. |
Is the speedometer working - one of the codes points to the VSS, sometimes one fault can cause "others". Don't hold me to all of the below, it is a bit early and not much coffee yet :)
TCU Codes: 1-Lock-up solenoid 'A' circuit open or shorted. 2-Lock-up solenoid 'B' circuit open or shorted. 3-Throttle Position Sensor circuit open or shorted. 4-Vehicle Speed Sensor open or shorted - No signal from speedometer. 5-Shift Lever Position Switch circuit shorted. 6-Shift Lever Position Switch circuit open. 7-Shift Solenoid 'A' circuit open or shorted. 8-Shift Solenoid 'B' circuit open or shorted. 9-Counter shaft or transmission speed pulse generator open or shorted. 10-Coolant Temperature Sensor open or shorted. 11-Engine RPM (Ignition coil signal) open or shorted. 12-(No code 12 used) 13-Main shaft speed pulse generator open or shorted. 14- ? 15-Kick down switch circuit shorted. |
