Multiple misfires, rough idle, after doing a bunch of work
So today I took my upper intake off to clean egr port, also changed spark plugs, adjusted valves, cleaned IAC, cleaned everything I could, replaced gaskets. After all said and done, start it up after a little bit of cranking and has rough idle. Then cel came on with misfire on 4, 5 and 6. Any thoughts? Or good troubleshooting tips or where to start?
Everything worked fine before I did all that. The main reason for doing it was cel was on for egr insufficient flow.
Check idle Long Term Fuel Trim and Short Term Fuel Trim w/ OBD2 scanner. If high LTFT & STFT (> +20% combined) look for a intake air leak on front cylinder head intake. A reduction from idle values of LTFT & STFT at higher rpm (2000-3000) also suggests intake air leak.
KaboomCult
07-07-2012 10:58 AM
98Accord220HP
07-03-2006 11:23 PM
