First time Honda owner at 54!
Hello, I've just purchased my first Honda, a 2007 Accord EXL-V6 with 96k on her. Bought from original owners yesterday (an older couple) who said its been in the shop only for routine maintenance, brakes, etc. I know about changing the serpentine belt by 100k, is there anything else I need to know to do my part to help it live up to the great Honda reputation? Also, I do have an issue I would appreciate some help with. The door on the storage compartment ahead of the shifter is stuck closed. Any suggestions would be appreciated. Thank you in advance.
A few comments:
Welcome!
A couple other general things... If automatic transmission, drain/fill the ATF with Honda fluid. Not sure what's a good interval, some people say every 30k miles? Power steering fluid is also special for Honda. Don't use the stuff that says "all makes". |
Congratulations on your purchase and welcome aboard! Make sure to show us your Accord, when you can - this way it will be much easier for us to provide you with helpful information. Feel free to reach out if you ever needed anything.
Welcome. It looks like a couple of us here are in the same age bracket.:cool: I bought my wife's 00 Accord (our 1st Honda) at 53 in Nov 2013, and that started our progression into Hondas. I bought my 97 Accord on her birthday in 2016, as a replacement for my old 92 Geo Prizm (Toyota Corolla clone), as it was showing it's age (mainly used as a winter car in the salt). Then I found the 99 Accord just around the corner from me that I got for 350 bucks. It's needed some work, but everything does work.:D
I think your 2007 uses a chain drive timing set up, and it's the tensioners that wear, causing the chain to stretch. I'm not 100% sure of that, but I think that's what Honda started using in 2003. |
Starting in 2003 Honda put a timing chain on the 4-cyl Accord engine. The V-6 still has a timing belt.
