Problem with my 98 honda accord 3.0
So my car started to idle funny. Needle starts going from 1 to 3 multiple times when i push the gas pedal my car starts to slow down n try an stop do anybody knowns what could be
Have you had the OBD-II codes read yet? If not, then that's a good place to start.
Originally Posted by shipo
(Post 375680)
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
P0705 - Short In Transmission Range Switch Circuit P1456 - Evaporative Emissions Control System Leakage Fuel Tank |
(Post 375684)
Any or all of the three could be the issue. Debugging Evap issues can be expensive, frustrating, time consuming, and (did I already say this?) expensive. The EGR and Tranny issues should be easier to diagnose and fix. That said, at this point I think you should take your car to a professional for diagnosis/repair.
(Post 375686)
The 0401 on the v6 is usually caused by the "tube" in the intake being clogged.
On the 98-02 the 0705 is a generic trans code....leave the range alone for now. The 1456 is going to be down to about three things in most cases....as stated testing would be needed to know exactly what is causing this. |
