Trying to help a coworker with her car.
First off thanks for looking. I have a co worker that has to get a temp tag every two weeks. I though i might give her some help and this is what i found.
2001 Honda Accord f23a4 (ULEV VTec) 185,000 miles 5 speed manual Here are the following messages i received using my enhanced OEM setting on my scanner H02S B2 S1 Heater Failure 02S S1 Heater Failure A/F S1 Lean Thermostat Range 02S A/F S1 Lean. I am not sure what she has done to it yet. She loves the car as i presume most of you guys do too. I would hate to see her get rid of the car because of it.She has had multiple people reset the codes and they just come back. I told her yeah they will come back cause something is wrong. Its not a magic fix. hah. Any help would be appreciated. |
You need to supply the codes (Pnnnn) that were present. Some info does not make sense. For instance, a 4 cylinder should not have a bank 2 code.
Heater failure is likely a faulty sensor, but could also be wiring, connector, or PCM. Testing necessary to be sure. good luck |
Good on you for trying to help her out. Good luck with it. |
ULEV engine has a different O2 sensor vs the non-ULEV engine. Some parts stores don't show that correctly when looking up the part. Just be careful about that.
