Accord Turbo
Old Feb 2, 2012 | 03:07 PM
Ty92's Avatar
Exclamation Accord Turbo
Which HKS Turbo would fit my 2002 Honda Accord 4cyl.
Old Feb 2, 2012 | 03:24 PM
Turbos are a generic part, meaning they aren't meant for any specific car. If you got a manifold with a T3 flange than any HKS turbo with a T3 flange would fit. If you got a manifold with a T4 flange than any HKS turbo with a T4 flange would fit. Assuming it is not too big to fit in the space.
Old Feb 2, 2012 | 03:46 PM
Ty92's Avatar
Exclamation
But one with to much boost could wreck the engine so I was asking which size Turbo would not wreck the engine
Old Feb 2, 2012 | 06:37 PM
g22cd5's Avatar
Supper Moderator
I suggest searching because you seem to know little no nothing about a turbo set up. Learn how a whole turbo system works. Then start doing research on what power goals you want. How much money you want to spend. It's not just as simple as getting a turbo kit and slapping it on your honda. You have to factor in tuning solutions. If your going to use a full EMS or how you are going to adjust your a/f ratio....and the list goes on.
Search search search...all the info is out there at your fingertips.
Old Feb 2, 2012 | 07:26 PM
Russianred's Avatar
Arrow
^ + 1.. You can't just be cut & dry about a turbo setup. There are MANY ways of doing it, knowing the principles of how the parameters of a good setup work is a good start.
You can enlighten yourself by reading this about 5 times in a row then coming back to ask something legitimate:
G2IC Turbo Guide - A Guide to Turbocharging your Honda / Acura Integra
To give you a better clue, a .57 or .60 trim Turbonetics or Garrett would work fine on a stock block at no more than 7psi, and a FLAWLESS tune. That should get you started..
I have the same engine as you do - boosted.
Old Feb 13, 2012 | 04:07 PM
Snoobly's Avatar
I coulda sworn i read somewhere that our block can handle up to 18psi? Was it probably just talking about the block and not the actual internals?
Old Feb 14, 2012 | 12:10 PM
Russianred's Avatar
Arrow
Yeah, block as in sleeves can probably handle up to 18psi. Piston rings fry at 9-11 psi depending on mileage, how the engine is maintained, and of course the A/F ratio of the tune.
Old Feb 24, 2012 | 01:33 PM
czr's Avatar
czr
im not trying to hijack the thread but what would be a good starting point to boost a F23A1 just for better gas mailage or is it pointless?
Old Feb 25, 2012 | 06:29 PM
g22cd5's Avatar
Supper Moderator
you can get good gas millage out of a boosted engine...as long as you don't spool the turbo
Old Feb 28, 2012 | 07:21 PM
Russianred's Avatar
Arrow
Truth. I have to say though, I got 28mpg even boosting in my 6G, and before I got the same mileage too. So depends how it's done and how often you boost, and how much you are pushing, and also on the way it is tuned.
