F23A1 Turbo Injector Recommendations?
What’s up y’all, I’m planning on adding a turbo kit to my Accord, but I’m struggling to find the right performance fuel injectors (most likely 440CC because I’m only planning on running 7 psi). The ones I see on eBay and other places are for the F23A5 non-VTEC. And the ones I see for my car are $70 ones from Chinese companies that I don’t know if I should trust.
I have a 98 LX 5-Speed, which is the F23A1. Would those injectors work for this too? Or could you guys recommend some? |
Originally Posted by acehonda
(Post 391479)
I have a 98 LX 5-Speed, which is the F23A1. Would those injectors work for this too? Or could you guys recommend some? Good luck I'm in the same boat even contacted some injector builders and nothing. I need 1,000cc for my build. lmk if you ever find anything |
(Post 391479)
I have a 98 LX 5-Speed, which is the F23A1. Would those injectors work for this too? Or could you guys recommend some? i ran 550cc from eclipse on my 00’. Fits perfectly. Mind you this was back in 07’ so im a little rusty on all I did. I was around on this forum back then so you may be able to find my posts with the whole breakdown of my build. |
