Please answer! Help!
i have a 1998 2dr accord with the j30a and have recently heard that i can get a j35a and put my j30a head on it with no problem. I also heard that this way you can turbo it, would this have the correct combustion ratio to be able to turbo around 6-8 psi?
Search and you shall find...info is out there you just have to search. You might not find what you need on this forum but use google it helps out...ALOT
It all depends how mechanically inclined you are, or how much money you are willing to spend. I have heard that the heads are interchangeable.
I wouldn't do any kind of power building on that car without a transmission swap. Personally, I would just sell it and buy a 2003 or newer V6 that didn't come with the slushbox that was in the 98-02 AT Accords. |
