Turboing a 1994 acoord
so i am thinking about possibly turboing my 94 accord in the future. it has the F22b2 and unfortunately 185000 miles on it. runs good and it is a 5-speed manual. i am going to be getting new belts and H2O pump. also the brakes are going to be done along with removing the A/C assembly as its a dead stick.
what else should i consider. i know ill eventually need new suspension, fuel system(pump, rail, injectors), also been told my clutch is getting a little old. i am going to get a compression test eventually, hopefully checks out. if not machine shop. what could i do to the valve train to upgrade? If i build the turbo kit myself, do a lot of the other work, is there an estimate someone could give me? I need a new goal. lol also did i miss anything, advice is appreciated in any form. |
RE: Turboing a 1994 acoord
Oh my...do more research before forking over 4k. Kevin can answer most questions about FI.
haha. yeah. ive tried. been reading a little. dont worry im in no hurry and well willing to learn anything. i heard that there was a magazine(do it yourself type thing) that did an entire rebuild of a car from that generation. did they do boost? maybe that can help.
im in the learning and research stage. i need pointed in the right direction. |
search for the parts you'll need... under the thread:
List by J_Man:(I added some stuff) -https://www.hondaaccordforum.com/Pie...m_82981/tm.htm List by Me: - https://www.hondaaccordforum.com/nee...m_55077/tm.htm Read both threads. Admins: Please post these threads in a visible place, since I've had to look for them at least 20 times in the past months. They are helpful for those boosting or at least considering boost. Will lowerFI questions. |
any questions, fell free to ask, I don't mind answering the same stuff over and over...LOL! Really, I don't mind...
Sweet, Kevin replied....your troubles are over clutch!
thanks. appreciate it. ill keep updated as i hope to get the comp test. question about that. whats good for compression on this particular motor. how close the cylinders are to each other or how each are to a certain number?
well just called and got a price, timing belt, H20 pump, ac bypass belt, compressor removal, compression test, valve check, maybe something else for $530 |
Hey Im selling my Entire Turbo setup .... Ive tried posting it but Cant ..... I will try again.,...
thanks for the offer but a little too much boost lol. i dont want to exactly have to rebuild the entire motor just yet and like you mentioned gas sucks lol. but again thank you and good luck with your sale
