North East ME, NH, VT, MA, RI, CT, NJ, NY, PA
2000 Honda Accord Transmission question
Old 07-19-2020, 10:03 AM
serta1's Avatar
Default 2000 Honda Accord Transmission question
Hello, I took my Accord 3.0 to get the transmission fluid changed. When I got it back I got several P07xx codes, one is P0740. I read that one of the causes is low fluid. I checked the fluid level and there is nothing on the dip stick. So did the transmission get damaged? I have driven the car 23 miles since I picked it up. I have to take it back but they are closed until Tuesday, 21 July. I am in NJ.
Thank you.
CW4 (R) Paul Sleeper
Old 07-19-2020, 10:07 AM
Seanjordan20's Avatar
Cheif! I know you're enjoying the retirement life.
The codes are the only thing that was going on? Did it shift correctly? What I would do is not drive it if you can and have them pick up the car with a tow truck on there dime. If all you were getting was the codes you're fine. It just needs more fluid added.
Old 07-19-2020, 10:27 AM
serta1's Avatar
Seanjordan20,
Thanks for the reply. I still work full time but been on furlough due to the Covid19 but the retirement helps. As far as the transmission, it was shifting fine before I took it in for the change. The fluid was really dirty. The first sign there was an issue was I noticed when I was stopped and started it was slipping. Then the codes started. P0700, P0705, P0706, P0740. I checked the fluid dip stick and nothing on the stick. The shop is about 2.5 miles from my house.
Paul
2000LX2.3
11-25-2017 03:19 PM
Kevin723
04-24-2015 08:33 AM
hp2003accord
10-15-2014 09:06 AM
Kerri
05-23-2013 11:57 AM
erader00
05-28-2012 10:42 PM
Quick Reply: 2000 Honda Accord Transmission question
