EPA MPG's Different Cars Same MPG's
The other day we moved our son back from college. About 95 miles each way. Wife traded the Minivan in on a new CR-V so we had to take two cars.
My Accord is a '14 with the 6 speed manual 2.4. EPA is 24/34. CR-V is a '15 and the EPA says 26/33. Same brand of cars, same engine but different transmissions. This trip was mostly highway, nice weather, no A/C needed. I got 36.4 and the CR-V got 27.6. That's a big difference for a 1 mpg difference for the EPA highway. The weights are similar, but the body style is way different. Shouldn't the EPA rating for the highway be about 9 mpgs different? Any thoughts on this? |
If CR-V has all-wheel drive, this will reduce gas mileage IMO due to extra drag of differential. There may be a significant weight difference. Wind drag on the CR-V is likely significantly higher than Accord.
Incidently, I have found the gas mileage from the trip computer to be somewhat optimistic, perhaps by 5-10 %. Occasionally, it will be close (< 5%), but never conservative. From what I've read gas mileage is calculated based on mass air flow and pre-determined fuel/air ratio (A/F sensor controlled). good luck |
I understand what you are saying, but my Accords computer is usually within a 1/10 or so, understated. So has the CR-V.
The other part I don't understand is are the EPA's numbers. I though they took into account the all wheel drive and much more wind resistance. |
Even though they have the same engine displacement, many variables come into play when considering mpg as has already been stated
Manual vs. automatic Body style = wind drag All wheel drive Load capacity Dual or single exhaust The driver behind the wheel It should be expected that the Accord with manual trans will get better mpg than a CR-V with automatic EPA ratings are merely a guide-line |
The EPA ratings are pretty much useless when it comes to real-world driving, even when it comes to comparing different cars. Said ratings are more formula based than fact based, and can vary rather dramatically compared to what one might expect on the roads.
A few FWIWs:
I always seem to beat the EPA's highway with a stick. Can get close with an automatic.
The EPA needs to try again. Perhaps actually drive the cars on a real road! |
Originally Posted by Corvair
(Post 360364)
