POST YOUR Mileage
  #661
Old 06-01-2017, 11:04 AM
Corvair's Avatar
'14 with 82,000. Only unscheduled costs were new tires and wiper blades. I'd still have the tires but this is Minnesota and I drive 32 miles each way to work. The legal minimum isn't really enough in snow.
I had got rid of my last car, an '11 Fiesta, by the time it hit 80K. 17 failures while I had it. Two suspension parts counted as one, as were the drive shaft seals. So I'm being generous with 17. Trips to dealer for repairs were easily over 50! I love my Honda!
  #662
Old 09-14-2017, 05:34 AM
BillieJackFu's Avatar
305000 ish Miles right now; original clutch (slips a little, but 5 years of unemployment makes it hard to fix things). People say get a new car and I'm like, I just need a new clutch to keep my A to B car going.
  #663
Old 09-14-2017, 10:32 PM
The Toecutter's Avatar
I hear ya, BTDT and did what I had to, to get thru to the end. But my A to B car (233K+) needs money thrown at it, so I'm not under it when it's slushy. It's getting an exhaust thrown at it, as I had a good look at it in the spring,and it wasn't that healthy back then. I decided to go with a Magnaflow, as it's stainless, and I live in the "salt belt". I've also got a PO420 code, so I have a Magnaflow Cat to put on as well. I hope that's it, otherwise it's a down pipe too.
It's (winter) coming whether I'm ready or not. :O I've got 2 wheel bearings that I'm hearing too. At least I have them here ready to go on.
  #664
Old 09-19-2017, 11:09 PM
jools's Avatar
425,000 ks, '93 Accord, never missed a beat.
  #665
Old 09-21-2017, 11:28 AM
Corvair's Avatar
'14, three years and month old. 93,000 miles. This summers mpg about 37. New tires at about 73,000. New wiper blades, air filter and recommended maintenance. A recall about the battery cable. No unscheduled repairs.
  #666
Old 10-17-2017, 12:44 AM
04 accord 246,000 miles Runs perfectly
  #667
Old 11-01-2017, 06:54 AM
dgp1961's Avatar
Almost A Senior Member
2009 V6 turned 128,000 on the way to work this morning. No major issues to date just regular maintenance stuff. In my opinion takes a bit more oil than I'd like but runs good.
  #668
Old 11-10-2017, 10:15 AM
Jet sitter's Avatar
I just turned 242K on my 2000 EX.
Distributer O-ring replaced @190K
New clutch at 209K replaced clutch slave at the same time (leak)
New front struts at 224K
O2 sensor @ 230K
Replaced oil pressure switch @232K (leaking)
Replaced timing belt/water pump twice
Change out anti-freeze every 80K
New plugs/wire/cap/rotor twice
Brakes replaced every 100K miles (replaced front/rear rotors last change)
Change out the MTF every 60K
Oil/filter change every 5K
Several sets of tires
3 batteries
Car runs great! Recently developed a "clunk" coming from the right front of the car. I'll be installing my snow tires in the next week or two and I'll check it out.
  #669
Old 12-05-2017, 02:31 PM
2004 Accord; 210,000 miles! This summer, replaced rear bearings, and all rotors / pads. Running like a dream, but am losing a little oil on front side of engine. (It seems to be at an accessory, but I don't have a repair manual to know exactly what's attached to the front side of the engine.)
  #670
Old 12-11-2017, 12:21 AM
cyclops2's Avatar
22 mpg in town. 134,000 on original 2007 V6. Big & hefty car.
Hondas are always noisy at speed.
Quick Reply: POST YOUR Mileage
