Time for A/C...
Old Apr 9, 2011 | 12:20 PM
dunnskii's Avatar
Default Time for A/C...
Replaced all the Schrader Valves, cleaned all area's, Leak-Tite all fittings, and Now, Ima pullin a Vacuum on the system to see how bad, or good it is, 1st time checkin this cars A/C system...Got my fingers CROSSED !!!
Old Apr 9, 2011 | 04:06 PM
Did you replace all orings? The orings seal, not the threads.
It should hold good vacuum for 15+ mins after vacuuming for 15 mins.
Suggest vacuuming for at least 1 hr before charging.
Is this a retrofit, R134a or R12 charge?
If you have leaks, some places to look are compressor shaft seal, evaporator expansion valve, and all connections.
Old Apr 17, 2011 | 11:08 AM
hondadude's Avatar
Another common leak is the pressure switch; pull the connector and look for oil in the connector well.
I don't retro fit with 134a, the molecule is way smaller than R-12, and you really need a larger condensor area.
Freeze-12 is S.N.A.P. approved and gives the same pressures and cooling as R-12.
Old Apr 17, 2011 | 11:41 AM
dunnskii's Avatar
It held a good vacuum, for more than enough time... And Ya, Ima using that Freeze 12. Some people say you can just use r-134a, but it is structured different, and cant remove the same amount of heat needed, and achieved by r-12...134a is not as efficient as R-12 was, and I dont wanna do a total conversion at this time or any time soon...Still got one more week till I get my DL back...
WhiskeySlick
Jul 31, 2011 03:39 AM
squeek
Jul 3, 2008 09:03 PM
accordROB
May 5, 2008 10:00 AM
kriegz99
Jun 12, 2007 11:31 PM
EternalBuddha
Apr 16, 2006 09:34 AM
