2002 Accord Engine Idle Problem
O2 Accord engine idle from 600rpm to 1200rpm any suggestions will be greatly appreciated. Steve931:):confused:
Could use a better description...
Four cylinder automatic w/air
Haha, okay I guess.
Does it go up and down between 600 and 1200 RPM? Like a pulsing up and down? Most common problem is a clogged IACV (IDle Air Control Valve) on the back of the intake manifold. It can be taken off by removing the two 10mm bolts holding it on and the 2 coolant hoses running to it. Clean it with carb/intake cleaner and clean the carbon crud out of the ports on the intake manifold. |
Thank you very much for your time. I am a heavy equipment mechanic so I am a little lost on some of the automobile problems. This sounds like the fix I will try this and let you know. Again thank you. Steve 931
