06 Accord 4cyl and 6 cyl spring rates?
I was curious if anyone knows if the 03-07 accords have different springs between the 4 and 6 cylinder cars. I've got a set from a 03 v6 coupe and wasn't sure if it would be an upgrade from an 06 4cyl sedan
RE: 06 Accord 4cyl and 6 cyl spring rates?
They should be a bit different simply because a v6 weighs more than an i4, however, try searching some manufacturers and see if they use the same part for a v6 and i4, chances are they won't but it 's a good way to double check
I'm just wondering if it would be a spring rate upgrade
