19 inch rims
ORIGINAL: cjdm98
I wouldnt go over 18,thats just me,although from what ive read..19s make for a bumpy ride.
Negatives of 19" wheels and suitable tyres (relative to smaller diameter rims with suitable somewhat higher profile tyres):
Inferior handling performance (because of excessively short / stiff sidewall)
Inferior handling performance (because of increased unsprung weight)
Increased harshness (because of excessively short / stiff sidewall)
Increased rotational mass (slower acceleration / impaired braking because of heavier rims)
Increased risk of rim damage (because of excessively short / stiff sidewall)
Increased risk of sidewall damage (because of excessively short / stiff sidewall)
Greater sensitivity to steering and suspension geometries (being correct or not)
Possible increased tyre wear (because of excessively short / stiff sidewall interacting with less than perfect geometry)
Looks silly (because it just does)
Positives-
Increased steering response (because of short / stiff sidewalls)
Umm.......
Positives-
Umm.......
ORIGINAL: JohnL
4 cyl takes the 19" rims with the following size
tires...25/35/19
Also your rims should be a 4 lug hole wheel if you have the 4 cyl engine...4X114.3 mm offset runs @ 35-42mm
tires...25/35/19
ORIGINAL: WheelBrokerAng
tires...25/35/19
tires...25/35/19
