1997 Accord Upper Ball Joint Loose - Needs Replacement
I'm a bit confused at how to fix this. Is this a bolt on item or does it need to be pressed on/off? If pressed I'll have my mechanic do it. If not I'd like to give it a go but am not sure how to do so.
Any help is appreciated. Vehicle Info - 1997 Accord SE 4 Cylinder Automatic 4 door. 217,000 miles. |
Is the process the same for a 97 that it is for this 95? If it's even close to that easy I can do that no problem.
YouTube - ‪Tutorial: How to Install an upper ball joint on a 1995 Honda Accord‬‏ |
yes 94-97 are the same.
it is recommended you replace the full upper control arm when you need to replace the balljoint. if you choose to put a new ball joint, get it tack welded on the top to keep it secure. |
