2014 Clunk/pop noise... PLEASE HELP!!!
I have 2014 accord sport with 10,000 miles. Recently it started making a popping noise like a metal slipped and shifted to the other side when i turn the wheel. The noise only happens when I try to pull out of a parking spot by going forward turning the wheel to left then reversing turning the wheel right and moving fwd again. The pop happens when I turn the wheel to change direction to left or reversing and the wheel is turning right. It only pops once. I took it to the dealer and the technician said its the break pads resetting itself. Its very annoying for a new car and I doubt its the breaks because its coming from the driver side only. The popping is very loud and rough on the hill compare to flat surface. PLEASE HELP!!!
Ball joints?
sounds like a tin can?? go back to the dealer and demand a further inspection, they blew you off the first time and for the amount of money you spent you deserve a more reasonable explanation. And if they tell you the same crap again tell them to spend 25/30k on a car and see if they would put up with it, i dont think so,
Hello Member
2 Attachment(s)
Originally Posted by Drocca14
(Post 352742)
