4th gen sway bar
I have a 91 accord ex and I'm wanting to put better sway bars on my car. I know some of the newer accords you can use the sway bars from the tsx, but is there cars that I could pull the sway bars from that will fit on my accord?
Good parts post..your site is really easy to use.. :)
Since 4th Gen Accords share pretty much the same suspension parts as 5th Gens, you have the same options I did when I was looking.
Suspension Techniques (ST): 27mm front (solid), 20mm rear (solid) Progress: 22mm rear (solid) Tanabe: 30mm front (hollow), 20mm rear (solid) I ended up going with Tanabe for a few reasons......I found a brand new set for sale on a forum for 1/3 of the new price. This was the biggest factor lol. But also, one thing that sets Tanabe apart from the others is that the rear sway bar is the exact same design as the OEM one. ST and Progress rear bars and shaped differently, and you have to drill into the sub-frame to mount them. So Tanabe had ease of install on its side as well. |
