94 honda accord LX suspension help!!!
Hello everyone. I have a 94 honda accord with 226000 miles with the original suspension. I want to change the entire suspension since theres alot of cracking and popping sounds when driving the car. It is my daily driver. Below is a list from Rockauto.com that I have created. Could you all take a look at it and see if Im missing anything or if I made a good choice with the brand of parts? I MAY lower the car with Eibach springs and I currently have tokico struts all around. Thank you for your help. Could you also recommend a good brand of front wheel bearings. Thank you all very much.
1994 HONDA ACCORD LX 2.2L 2156cc L4 MFI [F22B2] SOHChttp://www.rockauto.com/catalog/images/Gear.gifSuspension : Control ArmRelated PartsDORMAN Part # 520630 {#52390SM1033, 52390SM1A03, 52390SM1A04, 52390SM4033} Includes Ball Joint and Bushings; Rear Right UpperD$21.79$21.79http://www.rockauto.com/catalog/images/Remove.gifDORMAN Part # 520629 {#52400SM1033, 52400SM1A03, 52400SM1A04, 52400SM4033} Includes Ball Joint and Bushings; Rear Left UpperD$21.79$21.79http://www.rockauto.com/catalog/images/Remove.gifDORMAN Part # 520627 {#51460SV4000} Includes Ball Joint and Bushings; Front Left UpperD$24.79$24.79http://www.rockauto.com/catalog/images/Remove.gifDORMAN Part # 520628 {#51450SV4000} Includes Ball Joint and Bushings; Front Right UpperD$24.99$24.99http://www.rockauto.com/catalog/images/Remove.gifDORMAN Part # 520625 {#51365SV4000} Includes Bushings (Ball Joint N/A); Front Left LowerD$30.79$30.79http://www.rockauto.com/catalog/images/Remove.gifDORMAN Part # 520626 {#51355SV4000} Includes Bushings (Ball Joint N/A); Front Right LowerD$30.79$30.79http://www.rockauto.com/catalog/images/Remove.gifhttp://www.rockauto.com/catalog/images/Gear.gifSuspension : Ball JointRelated PartsAUTO EXTRA / CHASSIS RITE Part # AXK9643 {#RK9643} Front LowerB$6.33$12.66http://www.rockauto.com/catalog/images/Remove.gifhttp://www.rockauto.com/catalog/images/Gear.gifSteering : Tie Rod EndRelated PartsAUTO EXTRA / CHASSIS RITE Part # AXES3391R (Only 7 Remaining) Front Right OuterB$10.51$10.51http://www.rockauto.com/catalog/images/Remove.gifAUTO EXTRA / CHASSIS RITE Part # AXES3392R (Only 8 Remaining) Front Left OuterB$12.48$12.48http://www.rockauto.com/catalog/images/Remove.gifRAYBESTOS Part # 4011625B Service Grade InnerC$12.30$24.60http://www.rockauto.com/catalog/images/Remove.gifhttp://www.rockauto.com/catalog/images/Gear.gifSuspension : Stabilizer Bar LinkRelated PartsDEEZA Part # ACL612 Premium Quality (Only 18 Remaining) Front FRONT; From 03.93; To 02.96; 90112-SM4-020; MB831039A$7.64$15.28http://www.rockauto.com/catalog/images/Remove.gifDEEZA Part # ACL201 (Only 6 Remaining) RearA$13.75$27.50http://www.rockauto.com/catalog/images/Remove.gifhttp://www.rockauto.com/catalog/images/Gear.gifSuspension : Stabilizer Bar BushingRelated PartsRAYBESTOS Part # 5501308 Sway Bar Frame Bushing Kit; Contents: (2) Bushings Professional Grade; Sway Bar Bushing (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) (Only 3 Remaining) Rear Suspension; To Frame; 14.7mm Sway Bar DiameterCE$5.11$10.22http://www.rockauto.com/catalog/images/Remove.gifRAYBESTOS Part # 5501068 Sway Bar Frame Bushing Kit; Content: (2) Bushings - Rubber 22.2mm ID Professional Grade; Sway Bar Bushing (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) (Only 11 Remaining) Front Suspension; To Frame; LX |
| All times are GMT -5. The time now is 11:57 PM. |
