Front riding low!
Guys, my 93 accord has just over 208k on the clock and I’ve ignored a problem for a while now but it’s time to get it sorted out. The front driver side sits about ¾ inches lower than the passenger side, and with that much difference I’m able to see it from a ways off. That particular shock and all the others are bone dry and the car feels stiff when bounced and gives no sideways movement. I did tie rod ends and upper control arms yesterday since they were worn and took her in for alignment. The guy at Firestone didn’t notice it until I showed him and he, like at least 1 other person thinks it could be a worn coil spring. Has anyone seen this before? Thought I would let you know that I had the car since mid 07 and never did shocks! The tire pressure good also.Thanks in advance for your imput.
Sounds like a spring" is weak.
I would look around for "loaded" struts and replace. The "loaded" struts come with new coil springs and the strut. |
