high speed vibration ?
I've got an '03 Accord with Brigestone Potenza tires, 75,000 miles. After many re-balances and an alignment check, I still have a small vibration at 80 mph. Could this be a wheel bearing going or someother mystery issue like a sway bar link bushing going bad.
RE: high speed vibration ?
Describe a "small" vibration.
bent rim?
go and get your wheels balanced again they didn't balance them correctly they most likely used the wrong weights and or possibly a loose wheel. Have them show you the alignment also i would just take it back there and have them show you each wheel weighs out to 0 after balance
ORIGINAL: david369601 I've got an '03 Accord with Brigestone Potenza tires, 75,000 miles. After many re-balances and an alignment check, I still have a small vibration at 80 mph. Could this be a wheel bearing going or someother mystery issue like a sway bar link bushing going bad. second reason: I had a tire that got a bunch of mud and crap in it somehow, didn't vibrate until 75. The shop took the tire off cleaned it out and everything was fine |
ORIGINAL: smaglik bent rim? |
Perhaps a worn tie rod end or ball joint? Internal tyre damage? Have you balanced front AND rear wheels?
ORIGINAL: sir_nasty I've had this happen for two different reasons on two different cars. One car they used rather large wheel weight which made them balance out but it needed to be distributed differently to prevent the vibration. so instead of one 5kg weight you use 5 1kg weights next to each other. |
LOL ... nice catch!!! Nate??? Did you mean grams?
ORIGINAL: falkore24 LOL ... nice catch!!! Nate??? Did you mean grams? |
