Mixing shocks..?
Say, for instance, I put two shocks of (a) kind in the front, and two shocks of (b) kind in the rear...Would this work?
just curious.. |
RE: Mixing shocks..?
Hi Member:
Shocks and struts are engineered to work best with there own make and model, there fore I will have to say no! ClickPic! [IMG] local://upfiles/22/37B74CBC9FE945FE9E698140E83B1B4C.gif[/IMG] [IMG]local://upfiles/22/37B74CBC9FE945FE9E698140E83B1B4C.gif[/IMG] |
I figured that...I was just curious to see if I could go with really nice shocks in the front and decent ones in the back... oh well!
Have a great evening this fine Christmas Day...
[IMG]local://upfiles/22/B62D26E37CB14052B5F607002CD2703D.jpg[/IMG] |
Same to you!
ORIGINAL: ohsmustangs09 Say, for instance, I put two shocks of (a) kind in the front, and two shocks of (b) kind in the rear...Would this work? just curious.. If you're doing it as a cost spreading stepping stone to upgrading all the dampers in time then personally I'd do it. If you were intending to upgrade to something a bit special like Koni Sports ('yellow') then you could initiallyfit the Konis at a soft setting (to more or less match the existing other dampers) until you get around to fitting new dampers at the other end, after which you might want to stiffen up all round(?). |
That makes since...I didnt think about how that would effect the handling...but i was just curious...
What are your opinoins on KYB GR-2 shocks? and, for instance, Eibach Pro-Kit springs?? I got those springs but no shocks yet! cant decide.... |
ORIGINAL: ohsmustangs09 That makes since...I didnt think about how that would effect the handling...but i was just curious... ORIGINAL: ohsmustangs09 What are your opinoins on KYB GR-2 shocks? and, for instance, Eibach Pro-Kit springs?? I got those springs but no shocks yet! cant decide.... |
