rotor install q
[align=left]is there any way for me to check that the new rotors arent dragging on the pads? i just installed them, just wanna make sure theyre not dragginn. any tips?
[/align][align=left] [/align] |
RE: rotor install q
bummp? any responses?
RE: rotor install q
Brake pads will slightly "drag" on your rotors when installed correctly. Too much drag is ususally found with either measuring turning torque with a dial torq-meter or seeing if the inner pad wears more than the outer pad. There's no quick way to check. Also if one is dragging more than the other it could cause a brake pull.
