2006 banging over bumps
Have a 2006 that just hit 100,000 miles.
The potholes seem to have taken their toll.
Replaced the front struts a while back.
The car really rides rough over bumps and seems to be getting worse.
Is this the rear struts or is something else going on here?
Not sure where to start.
Thanks in advance for any help.
I just traded in an Accord 06 Coupe, 6 speed manual w/Navi. I had the same issue. Replaced most everything in the front end trying to find the "Klunk". It turned out to be the axle shafts. Replaced them, and it was gone. End of that. The joint was loose, going over ridges in the road, slight bumps, it was klunk. Put car up on ramps, grab the axle the best you can in the middle, or use a breaker bar, and see the play. Apparently, this is pretty common problem. Suggestion: Spend the bucks, get the original Honda shafts, less problems.
thunder_x
12-10-2007 10:24 AM
