SQueeking SHOCKS???
Does anybody know how i can get rid of my shocks awful squeeking? it doesnt make noise at high speeds but when im cruisin through town and the car is bouncing the shocks squeek alot. is there anything i can do to get rid of it? or should i just change the shocks?i have a lowering kit on the car
RE: SQueeking SHOCKS???
how old are the shock/strut cartridges in question? it could just be the bushings squeaking, are they OEM rubber or urethane/delrin/plastic composite?
If its coming from the rear, check the rear subframe bushings, or the bushings that the rear shock assembly is bolted to. |
Sounds like bushings. Try bouncing the corner of the car while parked to identify the wheel(s) making the noise.
sounds like spring chatter. coat the top few spring coils with a coating or heat srink. stoped my squeak.
