Suspension for my 04
im wondering if anybody can help me out..i have a 04 accord sedan with 20x7.5 wheels with 225/35/20 tires..i was wondering how low can i lower it without rubbing...also what is the best combination of shocks and springs to mesh together on the ride for good performance...
is your wheel well full with thies 20s? if not since your rims are so bigh you might want the TEIN H-TECH. Theyre alll over ebay. If you want a lower drop 1.8 F;1.2 rear to even out then you probably couldnt put your fingre bw the tire and the fender. Id suggest measuring the gap then look at the TEIN prongs for how low you wanna go. I judt put my S techs on today. Im in an 03 coupe 0n 17s and ive got barely an inch. Try the teins youll like em.
The only thing is I'm not able to measure it...cuz wen I bought da car from dis guy...he had heated his springs so I'm not able to measure it....I want it as low as bein able just to put my finger in sideways...
I just put my teins on and there is about two fingers worth of spaceb/w wheel and fender. Its awesome, and they ride like they're stock. Buy them on ebay they go for about $200 search 04 Accord TEIN S-TECH and they'll be all over. Good luck.
By da way wat type of shocks are you using with them?
stock oem shocks and struts, the TEINs will fit right on
