suspension setup question
hi everbody. im intrested in changing my current set up tokico blues and intrax springs to something better. the ride is good but the back of my car is higher than the front. is there anything i can do to the current set up or should i get something else? also, if i was to change the suspension, should i get it were i can adjust the height of my ride because i live in new jersey and it snows during winter season or would i be ok in snow?
RE: suspension setup question
the only way youre going to get it any lower is different springs or coil overs, or you can be like some people and cut your current springs but if you mess up on that you would have to get new ones anyways. As for the snow, its all going to be based on the tires you have and if lowering your car changes your camber, with me, my camber is fine but i have no traction in the snow..... and cause of that i have trouble accelerating and stopping and thats purely because of my tires...... so as a note..... dont get street performance tires and 7inch wide rimms if you live in an area that snows
