1997, damper fork bolt question
Old 12-15-2017, 08:09 PM
75Gremlin's Avatar
Default 1997, damper fork bolt question
In the process of replacing the struts. When tightening the bolt at the bottom of the fork, should I:
1. loosely (hand tight) put the nut on the bolt while the car is still on jack stands, then lower the car to the ground, and tighten bolt to 65 foot pounds?
2. torque down the bolt to specs with the car suspended and with the wheel off the car?
It is a lot easier the second way, but I don't want to hurt the rubber bushing which could 'twist' when the car is lowered to the ground.
As a practical matter, does it really make a difference?
Old 12-16-2017, 05:47 AM
#1 - If you have it on stands, use the jack to lift the knuckle
Old 12-16-2017, 09:48 AM
75Gremlin's Avatar
Thanks
For anyone doing this in the future, is the bolt that goes through #13 in the attached diagram.
PremND
04-25-2013 11:27 AM
bce1015
01-27-2013 10:30 AM
nudosimmons
03-21-2009 04:08 PM
fendigyal
07-01-2008 10:40 AM
smaglik
11-06-2007 01:28 PM
Quick Reply: 1997, damper fork bolt question
