18in wheel fitment???
I found a set of 18in wheels I like but i dont know if they will fit. They are 18x8 with 47mm back spacing and 235/40/18s. if anyone can help me out that would be great
Backspaceing should be alright! it runs a High Offset which is 42-55mm..Ang:D |
RE: 18in wheel fitment???
well it all depends......what kind of accord do you have? because the V4's usually have 4 bolts on the wheels while the V6's have 5 bolts on the wheels.
It is a V6. The bold patern is right i am worried about the with.
ORIGINAL: daytonphotog I found a set of 18in wheels I like but i dont know if they will fit. They are 18x8 with 47mm back spacing and 235/40/18s. if anyone can help me out that would be great If you have a 98' to 02' Accord with 5 lug holes you can use 225/40/18's so it dont matter..What Does Matter is if you have 4 lug holes or 5 lug holes and you have a 98' to 02' Honda Accord ;) WheelBrokerAng: hope this helped you ;) |
I have 18's on my 2002 4cyl coupe with 235/40/18's and a 45 offset. I have no rubbing issues at all. i don't have a drop but plan on dropping front 1.5 and back 1.2 (tanabe gf210). However, the front wheels stick out past the fender just a little bit. I dont know if anyone else has experienced this or if I like it or not, but at this point, i have no choice - tires bought and paid for. does anyone else with a 235/40/18's or with 225/40/18's, both with a 45 offset have this problem? not sure if it is the wheel or the tire that makes it stick out. anyway, if i drop it with the tanabes, would i end up rubbing?
