2014 EXL Navi Front Tires unusual wear
Hi All, I have been experiencing some issues with the wear of my front tires, the wear is excessive at 20k miles, similar to when you have bad struts and the tire wears off in the outside of the contact surface. I talked to the dealer and they said is a problem with the tires, and they talk to goodyear (have goodyear assurance) and they said the problem is due to bad or extreme driving habits!!! No surprise to me about their response. I took on the task on checking all other accords from this generation that crossed my way and surprise surprise!! All accord drivers have very bad driving habits! I have checked about ten vehicles with goodyears, continentals and Michelins and all have the same problem, in my opinion is a problem with the redisigned front suspension of accords. Any one has the same issues? please check your tires. I will share all the pictures i got from other vehicles. Thanks
This are the pictures taken from different vehicles.
4 Attachment(s)
Here are the pictures, I have lots more.
Hello Member **
2 Attachment(s)
I'm going to move this to the Tire and Wheel thread to get some play on it..Must post in areas where they will get you some answers..:)
It's not likely that Honda will do anything for you, so before you keep destroying tires, find a good alignment shop. Clearly explain what you have found and tell them you want it straight even if a camber kit needs to be installed.
This helps explain alignments more if you want to read up on it. http://www.tirerack.com/tires/tirete...e.jsp?techid=4 |
