can these tires fit my stock rims?
Hello, so i was wondering if my stock alloy rims on my 06 accord (ex)
ALY63907U10 Honda Accord Wheel Silver Machined #42700SDAJ01
can fit 215/60/16.
can fit 215/60/16.
can fit 215/60/16.
https://www.amazon.com/Westlake-RP18...ustomerReviews
can fit 215/60/16.
Ok, sweet thanks! So look wise will the tire be bigger or smaller, I know they will be a little wider but was hoping everything thing else was same
quote:
"Hello, so i was wondering if my stock alloy rims on my 06 accord (ex)
can fit 215/60/16."
I have been looking into the same thing for an 2012 Accord SE, same wheel/tire size. In my case I was concerned with wet/dry braking and handling which meant a UHP tire not available in the OEM size for the SE.
I agree with abestar, a 225/55 R16 is almost a perfect match although it's an odd size for some tires.
You might want to take a look at this site:
https://tiresize.com/calculator/
It has a size comparison calculator and will show a graphic display of the difference in size between two tires as well as the speedometer error.
discount tires site has a similar calculator that isn't quite as good but will work for a quick comparison. As a last step, Tire Rack is always a good place to check. Local dealers aren't always up on tire size changes with specific wheel sizes.
can fit 215/60/16."
07 Accord Tires
can fit 215/60/16.
can fit 215/60/16.
They will probably clear with no rubbing except possibly at full steering lock. That said, your speedometer and odometer will both under report speeds and distances due to the larger diameter of the tires.
07 Accord Tires
Try the same thing with 205/60 or maybe 205/65 tires & see if it'll let you check out. It may be the rubbing is against the sidewall, not the tread. But the thing about the speedometer and odometer being off is still gonna be true.
And if you just want to do it anyway, you can go to the website and shop by size, not by car-model. Of course, if they rub badly then it's your own fault...
