what is a safe/close to factory offset
hi members,
Im looking to get 20 Vossen cvt for my 2011 ex-l sedan. and was wondering what offset is good? also goin to lower it on coilovers. any help is appreciated. thanx |
Go to tirerack.com & see what 20" wheels they list for your car. In their specs, see the range of offsets for all the wheels, to see what'll work. Especially pay attention to the rim width along with the offset.
Much larger & wider wheels, you don't always want to stay with the same offset. It depends on where the first interference is located. Outboard interference (fender lip, etc) means you need larger offset. Inboard interference (spring/shock, knuckle, etc) means you need less offset. |
thank you Jim blake i will go and check that out.
