Wheel Vibrating Noice! Please help!
Hello.
I have a accord 91 mod, with custom spinners 18" x 7.5". These accords shouldnt have more than 17" x 7". Anyway, last summer i used these same wheels a session, and when i putted them on for the summer session 6 months later, there was a very irritatin noice up from 40 mph. When i turn hard, the noice disepear. I thought it could be air pressure, but it wasnt that. The rotation direction is also correct. The confusing this is, that only the 2 wheels on the left side of the car, has this problem. The 2 wheels on right is "peacefull". Any ideas?! Can it be tired springs, or wheel balancing? The car and rims is not crashed or damaged at all. The problem is freekin me out. Please help. |
RE: Wheel Vibrating Noice! Please help!
There is NO reason to post your question/problem twice in seperate areas. Please do not do it again. As people have time they will try to assist you but it is less likely you will receive help if you continue this type of request.
Swap the left and right side wheels and see if the right side has the same problem. If it does then it is in the wheels or tires. If not, then it is something in your suspension on the left side.
Ok...I didnt know where to post it..It could be wheels or suspension..
Afterall, im from norway so i suppose my english is not that great:P What did you mean about wheel swap ? |
J_Man_Honda is saying to change the wheels & tires from the right side to the left side and from the left to the right. If the noise moves to the right side of the car you will know that it is being caused by the tires & wheels.
Are your wheels or tires dirrectional rotation only???
WheelBrokerAng :eek: |
Yes, my tires is dirrectional rotation only.. So..I guess if we move the tires and wheels like j_man_honda said, would be pointless? I cant drive with the rotation direction wrong way?
You could do it for 2-3 miles R34accord and it wouldn't hurt anything. Just long enough to see if thats your problem.
