wheels and tires 18s?
Hi I have a 2011 accord se and im looking into getting the (AR907 PVD) in 18s. also what tires can i go with without rub? Will it work?
Go to TireRack.com and plug your car in; everything will be revealed. :)
Originally Posted by shipo
(Post 375132)
Most of those have much lower offsets. I fear that it won't work right. |
Originally Posted by Tuberculosis
(Post 379515)
My concern with sites like that is that the wheel may fit, but how far does it stick out?
Most of those have much lower offsets. I fear that it won't work right. Edit: I need to add one qualification to my previous statement; if you've lowered or otherwise modified the suspension to your car, then all bets are off. |
(Post 379523)
If you put your year, make, and model in and select wheels and tires for that car, they will only show the ones which will fit.
Edit: I need to add one qualification to my previous statement; if you've lowered or otherwise modified the suspension to your car, then all bets are off. For instance, the car comes stock with 8Jx18ET55 wheels, and while I'll probably be looking at 18x8.5s, tirerack.com claims that a set of 9.5x20ET53s would fit both the front and the back just fine, but that doesn't sound right. Are you sure? Thanks |
