Will these wheels fit?
Will these wheels fit a 2010 honda accord coupe? will i have any issues with TMPS? will ride quality suffer?
Brand New 18" x 7 5" Replacement Wheel for Hyundai Sonata 2011 2013 Rim 70804 | eBay |
The facts here they are..Hyundai Bolt Pattern. 5x114.3 - Hub size 67.1mm, - Offset or ET 35-44 mm, - Lugs or Nut size 12x1.5mm . Will need new TPMS's, - Tire Size 225/45/18"
Honda Coupe : BP. 5x114.3 , - Hub 64.1mm, - Offset 40.55mm, - Lugs same.., Tire size 235/45/18" . New TPMS's Wheels and tires in these sizes should fit..but you would want to check clearance very carefully. The 235/45/18" tires are 2"s higher than the 225" tires. Hope this helps your decision. :) |
(Post 357687)
forgot to mention my accord is a 4cyl ex...so stock tires are 225/50/17. Will these tires fit the new rim?
Ride will be a little stiffer. TPMS almost always have to be changed cause the usually get wrecked by the tire installers who are never carefull, they WILL have to be re-programed with the installation..cost is kinda high.
(Post 357692)
