-   Tires & Wheels (https://www.hondaaccordforum.com/forum/tires-wheels-15/)
-   -   Would 215/65r16 tires fit stock OEM Honda Accord rims? (https://www.hondaaccordforum.com/forum/tires-wheels-15/would-215-65r16-tires-fit-stock-oem-honda-accord-rims-35691/)
Andrew James Oct 20, 2010 11:09 PM
Currently running 205/60R16s, any issues in running 215/65R16 tires?
2000 Honda Accord, 16inch stock OEM rims.
Thanks.
Andrew James Oct 21, 2010 11:55 PM
No replies?
WheelBrokerAng Oct 22, 2010 02:06 AM
Those will fit the stock rims...
Andrew James Oct 23, 2010 03:13 PM
I didn't think it would be a problem, just making sure there would be no issues.
g22cd5 Oct 24, 2010 08:05 AM
are you lowered?..might have rub issue if your fenders aren’t rolled.
WheelBrokerAng Oct 24, 2010 02:56 PM
Okay then...
Happy Football Sunday!
Andrew James Oct 25, 2010 08:51 PM
Thanks guys!
Stock Accord, no aftermarket whatsoever.
Jacob D Nov 5, 2019 10:14 AM
Did they fit?
Hey Andrew did you ever go through with putting these on? I have a set of 215 65 16 sitting around hoping they will fit
shipo Nov 5, 2019 12:37 PM
The tires will fit on the rims but they will be both wider and taller than the stock tire size; said another way, you may experience rubbing/tire damage on bumpy roads or when you have the steering wheel turned full-lock. The other issue is your speedometer and odometer will under report your speed and distance traveled.
Kenneth Pino Jun 5, 2020 05:41 PM
215/65/16 tires on OEM wheels. Accord 2012
They fit and will give no issues. I have them fitted on OEM Honda wheels and the car performs flawlessly. Have not checked for speedometer accuracy.
