I don't think my 12 volt toaster oven is not getting enough amperage?
Old Jul 11, 2010 | 10:21 PM
MROOKIAN's Avatar
Default I don't think my 12 volt toaster oven is not getting enough amperage?
It is taking unusually long to toast my toast when I plug my 12 volt toaster into the 12 volt outlet of my car, even on maximum settings. I hooked up the toaster to the battery and it got real hot! Why am I not getting enough current to my 12 volt outlet? Having to wait 4 minutes for toast on the road is becoming real cumbersome. Help would be greatly appreciated.
Old Jul 12, 2010 | 08:24 AM
keep_hope_alive's Avatar
who makes toast on the road?
you need to share the power draw of your toaster. then you need to run a new wire for the 12V outlet from the battery. factory wiring can only support 100W or so. you've probably burned out your outlet and/or wiring.
once you know the wattage, you can determine the wire size necessary (or i can tell you).
most likely, you'll end up buying an amplifier installation kit for either 10awg or 8awg. then use the amp install kit to connect to the battery and ground to the chassis.
Old Jul 14, 2010 | 04:56 PM
MROOKIAN's Avatar
Default Thanks for the input.
I am pretty sure I won't need to put a transformer under the hood to give my toaster the power it needs. I will deffinitly try hooking a wire directly from the battery to the 12 volt outlet.
Old Jul 14, 2010 | 05:03 PM
This was a 1st....
Old Jul 14, 2010 | 07:00 PM
MROOKIAN's Avatar
I just realized that I put a double negative in the title.
Old Jul 16, 2010 | 01:08 PM
i knew what you meant.
Old Jul 18, 2010 | 09:02 PM
MROOKIAN's Avatar
My toaster oven has actually been working pretty good lately, and I didn't even do any fixes.
Old Jul 24, 2010 | 12:31 PM
Default Hey You All
KeepHope is on the Ball...why do you think he's the Sound GURU
Old Jul 24, 2010 | 12:32 PM
Arrow
Make mine Lightly toasted please...butter with no salt...
Old Jul 25, 2010 | 09:57 AM
i would make sure the wiring is up to par regardless.
