92 Accord Radio Install Kit?
Old 12-26-2006, 06:07 PM
RedCruiser's Avatar
Default 92 Accord Radio Install Kit?
Do I need an install kit to replace my stock radio on my 92 Accord LX?
I already removed everything,and will buy the radio later today, but need to know if I need the kit to make it fit and avoid empty space on the dashboard.
Old 12-26-2006, 06:35 PM
sir_nasty's Avatar
Default RE: 92 Accord Radio Install Kit?
It all depends on what you have in there.... I believe the 92 was a single DIN deck size so you shouldn't need an install kit or anything. I would however, suggest getting a wiring harness to make installation a little bit easier but the new deck should have what you need to install it
Old 01-06-2007, 09:52 PM
Hey man do u think u could get me started on what to take off to get the old stereo out. Do i have to take out the whole dash part that surrounds the guages, ac control, and all that or does the old deck just slide right out
Old 01-07-2007, 02:44 AM
19Accord97
I would recommend Scosches wiring kits at Wal-Mart for $10 compared to other places $20 for the same thing. However do not waste your money on Scoches install kits...absolutely awful. I used one, returned it. Then on my sisters car, I bought an install kit that the place uses (they do custom installs and such) and it was a pile of junk too. I would ONLY recommends Best Buys install kits. They are the best kits ive seen and used. The only reason I had to get a different kit for my sisters car was b/c it was after Christmas and everyone was out. Good luck.
Old 01-14-2007, 06:39 PM
Bers
I just replaced my 2001 Accord stereo. I did not need an install kit, but certainly recommend the wire harness. I posted the details of the install with pictures in this forum at https://www.hondaaccordforum.com/How...m_39167/tm.htm.
Old 01-21-2007, 03:58 AM
94acccorn
see the my post in the the replacement for a 91 accord it will be the same for yours. Two get the two bolts out I usually use a socket wrench with an extension and a wabler.
Old 01-26-2007, 12:56 PM
Mr_Accord's Avatar
You can put in a radio without an installation kit but the radio will move in and out, and i won't stay in position, that where you need an instal kit
Josh Lillywhite
04-02-2013 05:34 PM
neihouma
01-26-2013 05:58 PM
chilehead
02-15-2010 12:06 PM
cengland84
10-28-2008 01:20 PM
F23AccordLX
02-24-2006 05:24 PM
Quick Reply: 92 Accord Radio Install Kit?
