89 accord wont start
Old 04-12-2005, 09:27 AM
booter
Default 89 accord wont start
the problem is the car wont start, i had symptoms for about a week, when the car would get near empty it would run badly when you first start it, only on two cylinders, drive a few minutes and then it kicks into three cylinders, and a few minutes later all four are firing, after you fill it up, no more problems, the last time the car got low on gas it died, and hasnt started back. i changed the distributor, the fuel pump is working fine. and i changed spark plugs and plug wires, no fix... any help?
also when the car was running, it surged at idle, any help with that would help too.
Old 04-12-2005, 10:32 PM
Default RE: 89 accord wont start
how long ago was fuel filter replaced?
also may be the carburator needs to be cleaned?
also - i'm thinking the evaporation from the gas tank might be clogged (i'm guessing here) it takes time for fuel pump to build pressure when the tank is near empty.
when you fill up your car - does it fills up regulary or pumps unclicks with some intervals?
Old 04-15-2005, 06:45 PM
booter
it is fuel injected i dont know when the fuel filter was replaced but i took the gas line off at the injectors and it sprayed lots of fuel all over the place
Old 04-17-2005, 10:49 AM
Start from replacing your fuel filter
Old 04-18-2005, 11:36 PM
booter
well i really dont think it jumped time, but that is my final thought, bc it is firing, getting fuel, and getting air, the ignition works, the coil and distributor are good and it still dont start.
Old 04-24-2005, 01:20 PM
i'm pretty sure its a bad ground somewhere - check the computer ground and/or computer
Old 04-25-2005, 05:15 PM
booter
do you think you can give me specific points to check the grounds, its weird that crossed my mind, but i know a mazda, not a honda... but a weak ground sounds like a pretty good explanation.
Old 04-26-2005, 11:24 PM
yes - its kind of old pictures - but it's the best i can send you
mmm how do i post the pictures??? send me your email i'll mail them to you
Old 04-28-2005, 02:39 AM
booter
staind_life@msn.com
Old 04-30-2005, 10:22 AM
it will take me a while ok - please be patient
Quick Reply: 89 accord wont start
