Crankshaft Pulley Bolt Removal - Ideas???
Old 10-28-2006, 01:53 PM
Staged206K
Default Crankshaft Pulley Bolt Removal - Ideas???
I have a 95 2.2 liter and am trying to remove the crankshaft pulley bolt that is torqued to 180lbs+. Timing belt replacement time, first one at 206K milers. I tried wedging a screwdriver in between the flywheel and thought it was working with my extended prybar/socket until I saw the screwdriver bending so I stopped and removed it. My impact wrench only goes to 110 lbs and is of no use. Any ideas to loosen it?
Autozone didn't have the hex tool for the crankshaft dampner. The Honda dealer has one but won't lend it out and says that they won't loosen the crankshaft bolt because it unsafe. Torches come to mind but I'd probably screw that up. Any ideas?? I'm all ears....
The crank turns counter clock wise like loosen the the bolt so I can't wedge the breaker bar and bump the starter to loosen it....I'm lost here. Anyone sell or loan out this crankshaft dampner hex tool????
Thank you for any input.....
Old 10-28-2006, 04:19 PM
YeuEmMaiMai's Avatar
Default RE: Crankshaft Pulley Bolt Removal - Ideas???
really large cheater bar or get an air tool (impact wrench)
Old 10-28-2006, 10:19 PM
Chiovnidca's Avatar
I use an IR261. 3/4" impact power. But I do em pretty often. A pulley holder and a piece of pipe would be cheaper.
Old 10-29-2006, 02:09 PM
deserthonda's Avatar
go to a shop and have them loosen the bolt just enough that it is safe for you to drive home and you can then remove it ,, you might have to pay 20-30 dollars ,, if you frequent the same shop for needed work they might do it free of charge ,
Yo CHio ,, that 3/4 inch impact works pretty darn good ,,I named mine BETTY ....that is not a bolt that BETTY cannot remove
Old 10-29-2006, 08:36 PM
Chiovnidca's Avatar
I named mine the Big Bastard. It hasn't failed me yet.
Old 10-29-2006, 09:33 PM
ORIGINAL: Chiovnidca
I like that
Old 10-30-2006, 06:25 PM
sir_nasty's Avatar
I think I'd have to take the old school video game name and just call it the "BFG" or Big Fricken Gun....
Old 10-30-2006, 08:11 PM
sir_nasty's Avatar
Here's a "farm boy" way to hold that pulley.... take the old belt, wrap it around the pulley, put a pair of locking pliars on the bottom of the belt so that it locks the belt on there, then have someone hold it or find a way to slide a wrench through the other end of the belt and brace it against the frame, then get a big breaker bar and pop it loose.... this belt/locking pliar setup also works good as a makeshift oil filter remover
Old 11-02-2006, 04:27 PM
lightshow's Avatar
you could take one of those chain wrenches but it will almost certainly ruin the pulley. i would say just plop down the 80 bucks and get the wrench. where do you live i have en extra one that i wouldnt mind selling.
Old 11-03-2006, 03:24 PM
Fenix's Avatar
or you could have the shop remove the bolt, and then get your car tow'd home. If you have Triple A they tow the first three miles for free
Quick Reply: Crankshaft Pulley Bolt Removal - Ideas???
