Header fitment
Old 05-19-2016, 10:25 PM
Thorsteenster's Avatar
Default Header fitment
I'm possibly looking at replacing the exhaust manifold, downpipe, and shortpipe with a cheap header. I need to find an exhaust leak, which I suspect is in the gaskets on either side of the short pipe between the downpipe and cat, which those parts are going to run $50.
CarID has a Spec-D header for $108, another reason I'm thinking of doing this, at some point I'd like to replace the F22B2 which shouldn't even be in it with a JDM H22.
Although the Spec-D seem to be of dubious quality, and O2 sensor holes not well placed.
Any help to fitment, and recommendations for a decent header in the sub-$200 range, or even closer to $100 would be greatly appreciated.
Thanks!
Old 05-20-2016, 01:55 AM
Don't know any other brands of headers, but I can tell you that a f22 header wont fit an h22.
Old 05-21-2016, 05:46 AM
Start the car cold, run you hand with a rag around the exhaust and see if you can find the leak.......you could also run a bit of seafoam through the engine (lots of smoke ) and look to see where the smoke is coming out of the exhaust system.
daytonphotog
07-12-2007 11:25 PM
just2asian
02-28-2007 09:28 PM
qnguyen209
02-18-2007 05:39 AM
BLuEPiTBuLLz
02-09-2007 02:44 AM
F23AccordLX
03-01-2006 08:13 PM
Quick Reply: Header fitment
