Sponsored by:
Sponsored by:
2000 Accord v6 coupe wont start when hot now, used to not start when cold.
Old 07-09-2012, 11:44 PM
gasface11's Avatar
Default 2000 Accord v6 coupe wont start when hot now, used to not start when cold.
I've been reading on the forums about the fuel pump relay and the master relay causing trouble. Here's why I must ask the question: the car used to not start (it would crank strongly but wouldn't start, like no fuel, etc.) in the morning when the outside temp was in the sixties. This happened 3 times in two weeks. I changed the coolant temp sensor. In the last week the same failure to start happened four times but each time in hot weather. Once about four days ago it wouldn't start early in the morning also. Of course after five or so min, the car started easily. Is it the main relay or is it the fuel pump relay or something else? What do you think, please
Old 07-10-2012, 01:14 AM
my1st.honda93's Avatar
sounds like the main relay under the dash i had the same issue then i replaced the relay and problem solved
Old 07-10-2012, 02:09 AM
gasface11's Avatar
So you had starting problems both at cool and hot ambient temperatures? Or was it only when the vehicle was hot?
Old 07-11-2012, 01:24 AM
both cold an hot but mostly when it was hot
Old 07-11-2012, 06:57 AM
gasface11's Avatar
That seems to be exactly what is going on with mine. Thank you so much for the input.
Old 07-11-2012, 12:33 PM
Silver6gen's Avatar
are you sure that you are getting spark?
cliburn
04-02-2012 05:37 PM
88accorn
07-11-2010 09:10 PM
BHoward711
04-12-2010 08:57 PM
shad9876
09-02-2008 09:56 AM
latoilette
01-09-2006 03:43 AM
Quick Reply: 2000 Accord v6 coupe wont start when hot now, used to not start when cold.
