Sponsored by:
Sponsored by:
Portable GPS in 96 Honda Accord???
Old 07-17-2011, 06:50 PM
poynterandy's Avatar
Default Portable GPS in 96 Honda Accord???
So I have a 1996 Honda Accord LX, 4 door, 4cyl. It has a regular Cigarette lighter BUT it doesnt work. I've been wanting to figure out how to fix the Cigarette lighter outlet so it will charge my GPS or convert the cigarette lighter to a connector that will charge my GPS. I say that because Im not sure if the stock output will work with a gps or if I have to install a converter so it WILL work. Any ideas guys? And if its not possible, then how do I fix the Cigarette lighter so it will work? Thanks
Old 07-17-2011, 07:44 PM
You need a volt meter. You will have to remove the center console, then remove the radio bezel. Unplug the connector going to the lighter. See if the wht/red wire has 12V to ground with the key in the II position.
In the common DIY thread on top of the gen tech help forum, there is a link to online shop manuals. The hondatech link has a 94 shop manual you can download to see how to remove that console and bezel.
Old 07-17-2011, 09:58 PM
Thanks, so if I remove this and repair it then would the GPS work plugged into the cigarette lighter?
Old 07-17-2011, 10:18 PM
It should. You need to figure out if the socket is getting voltage first.
Old 07-17-2011, 11:15 PM
Its not getting voltage, so what would I have to do to fix the problem?
Old 07-17-2011, 11:57 PM
Look at that shop manual for the 10A fuse #11 for the lighter. It is under the driver's dash.
If no voltage on that wire, then the next step is to test the lighter relay. If you find a similar relay, you can switch them out to see if the lighter will work.
If you have voltage, you need to test that the black wire has zero resistance to body ground.
carid
12-05-2014 03:01 AM
Aliakbar
01-25-2014 09:18 AM
Naodai
07-04-2011 11:40 AM
StrikingAccord
04-25-2011 06:13 PM
junyea
10-24-2006 09:57 PM
Quick Reply: Portable GPS in 96 Honda Accord???
