Sponsored by:
Sponsored by:
2003 power steering pump install
Old 12-30-2011, 12:35 PM
one54ton's Avatar
Default 2003 power steering pump install
Anything i should be aware of looks pretty simple.
Old 12-31-2011, 08:27 AM
About the only thing I can think of, be sure you replace the o ring on the line.
Old 12-31-2011, 10:39 AM
Why are you replacing the power steering pump, is it because of a whining noise? If so, try replacing the o-ring to see if it goes away. See link for copy of TSB:
http://honda-tech.com/attachment.php...8&d=1240155507
If you do need to replace the pump, see attached image. Remove the tension for the drive belt, by applying a wrench/socket to the auto-tensioner (IRRC, it should be a 13mm). Disconnect hose and then a few bolts...
Attached Thumbnails 2003 power steering pump install-power-steering-pump.jpg
Old 12-31-2011, 10:48 AM
Talking There's A Good Answer From Both Men **
After re-search on the subject, I believe Dave and Scott have given you the correct information..when your sure..Let them and all the members know if that did it for you.
Attached Thumbnails 2003 power steering pump install-champagne-ice-bucket-funny-animation-01.gif
Old 12-31-2011, 01:50 PM
6-Speed's Avatar
If you're replacing with a re-manufactured pump, expect to transfer the pulley and the inlet pipe from the old pump to the new one. You should also replace both the inlet and outlet O-rings; they may come with the new pump.
Put some rags over the belt/pulleys beneath the pump to catch any fluid that could drip on them when you remove the P.S. lines.
Old 12-31-2011, 02:07 PM
Mine is also making the whining noise when its cold after that it goes away..i will try just replacing the o ring see if it goes away thanks.
2003 v6 6spd cp
Old 01-03-2012, 08:41 PM
one54ton's Avatar
Well pump is install and noise is still there. My power steering pumps shad fat and a ton of play in it and I'm very glad I replaced it. As for the noise mine did it at all times. Now I'm curious if it's something like the belt tensioner of the alternators pulley.
Old 01-03-2012, 09:02 PM
Well, you can pull the serp belt off and start the car.....then you will know if it is the ps/alt/ac/idler or that....
Old 01-06-2012, 08:57 PM
Don't run the 2003 4-cyl without a belt for more that a few moments. It drives the waterpump too. I realize we're mostly talking about the V-6, but some people might read this thread & not realize that.
My 2003 4-cyl got a noisy tensioner pulley while the PS pump was fine. So that's certainly a possibility. When I removed the belt, that pulley had a lot of wiggle to it.
WhyNotFab
09-30-2006 05:25 AM
Rizzie
08-21-2006 03:26 AM
BDN54
03-09-2006 02:34 PM
WS6M21
12-04-2005 11:37 PM
WS6M21
11-09-2005 01:50 AM
Quick Reply: 2003 power steering pump install
