96 Accord Runnining hot after water pump
Old Apr 25, 2013 | 03:26 AM
schoust's Avatar
Default 96 Accord Runnining hot after water pump
Hey Guy's
I'm haveing a bit of an issue with my 96. I recently changed the waterpump and followed the book and others instructions to the Letter. Yesterday drove home around 35 mlles pulled up to my mail box to read somthing. I glanced down at the gauge to see that it was hotter than normal. Not sure what happened but suspect she may be air bound?? The thermostat was new a couple months ago so that's out... Any ideas?
Thanks
Old Apr 25, 2013 | 08:49 PM
go-part's Avatar
Former Sponsor
Try bleeding the coolant system, you may have some trapped air in the system.
Old Apr 26, 2013 | 06:27 AM
schoust's Avatar
I have in fact I followed the instructions and bleed air at the goose neck then I let it run until the t-stat opened. Not sure what way to go from there?
Old Apr 27, 2013 | 08:26 AM
Were the fans on the rad running when the temp got high?
Old Apr 27, 2013 | 08:32 AM
Faulty thermostat seems a possibility. Was this an OEM thermostat? OEM's work noticeably better than aftermarket, more precise temp, and much faster warmup.
barritron
Nov 24, 2009 10:49 PM
pimpp1184
Nov 5, 2009 09:55 AM
TWDDS
Oct 26, 2009 10:18 AM
Julieanne1976
Aug 21, 2009 09:20 PM
Bocatrip
Nov 29, 2007 04:17 PM
