2007 Honda Accord Sedan Power Window Problems
Hi All,
I am having a problem with 3 of my 4 power windows. Driver's window works fine, but the other three windows only click when I try to roll them down. It acts as if the window lock is on, but it is not. I am not sure what to check. The car is not in warranty anymore (too many miles). Thanks for your help!!!
-Deborah
-Deborah
Please Read The Forum Posting Rules
Before you post a question or an answer...look to see if your posting
in the correct form.
This was the new member, introduce yourself thread..
If your wondering how you got over here...I moved you so that you get an answer from someone.
By the way..Thank You for joining up here in the HAF...
I have same issues, see the following thread:
https://www.hondaaccordforum.com/for...t=20182&page=3
I believe you will need to replace the master switch on the drivers side. For instructions, view this video:
http://www.youtube.com/watch?v=bEzq4HrRYuI
The cheapest place I found to order the part was here:
http://www.g1parts.com/ACCORD_HYBRID...50-sda-a14.htm
I have the same issue and have ordered the parts, so if you want to wait I will tell you whether or not this fixes mine and then you will know for sure. I am pretty sure this is the culprit though. Hope this helps!
I installed the new master switch today and am happy to report that the windows all operate flawlessly. A bit of a note on this though... once you replace your master you will also need to re-program your keyless entry since the receiver is inside the master. The procedure is relatively painless and worked for me on the first try. Here is the procedure that worked for me on my '07 Accord EX-L...
I have desperately attempted to find the replacement module/assembly/switch/... but I cannot find anything in the diagrams that looks like what I'm supposed to be purchasing. Can you please help me out with a part number or the name of the part so I can order a replacement as well? Thanx a #,###,###,###!!!!!
Part Number
No problem... part number and description are as follows:
35750SDAA14 - Switch Assy., Power Window Master
The link I posted before must have changed, so you can find it here:
https://www.g1parts.com/ProductDetai...=35750-SDA-A14
Good luck, hope this solves your problem as it did for me!
Same problem
Dear All,
I'm suffering from the same problem Deborah has gone through. Is there any advice for me on what to do???
Kola
Kola
Hi All,
-Deborah
-Deborah
thank you for the information on resetting the transmitter! i unfortunately ordered my main switch from honda for $190. autozone's supplier didnt make the switch anymore and it was during the heatwave we had. I resorted to the dealer and couldn't wait any longer. I am about to go reset the transmitter for my car hope it works! will post if it does.
