Removing rust from caliper...
I'm not really sure if the rust is from the caliper itself or if the rust is from dust from the rotor wearing from braking that settles on the caliper and rusts on it.
I plan on removing all of this with a hand brass brush and a dremel with a brass brush attachment (cup and disc). I'm just wondering if the original calipers come with some kind of special coating or something that makes it a bad idea to go at this abrasively. Is it just base metal with no coating of any kind? I don't want to hit this with brass brushes and clean it all up only to find out I removed some kind of special coating that leads to this stuff rusting faster.
Something tells me if it's already rusted and the rust is truly from the caliper any coating is already gone anyway but there's still a possibility the rust is not from the caliper itself.
I'm not sure if the calipers are made of iron or aluminum (didn't think about doing a magnet test at the time). But regardless I'm still worried that it could be coated aluminum.
It's an '09.
Ahh I forgot about steel. Welp I guess that's a possibility too.
I'm not sure what you mean by a punch? I'm planning on using a brass brush by hand (the wooden kind with the bristles on the end) and for the tedious parts I'm using a dremel or whatever rotary tool that takes brass brush attachments on the end (one of them looks like a disc and the other looks like a cup).
It's an '09.
MessAround
01-13-2014 06:24 PM
rodmathews
08-05-2007 10:49 PM
