89 accord Check engin Light (CEL)
So I can see there are many posts for CEL on accord. I took the 89 accord to a mechanic and he did a read out only to find that cylinder 1 had a misfire.. The plugs are new so he suggested to replace the wires, which we did,,They also suggested the gas cap, which we replaced. CEL is back on . I found a post that listed a web page to manually read the codes by jumpering a plug under the dash. Does anyone know of such a post for an 89 accord? I hate asking technical questions without all the data. Thanks
RE: 89 accord Check engin Light (CEL)
Hello Dandy new member:
Use this link to help you with your questions and also use the search feature up above :
www.troublecodes.net/honda/
WheelBrokerAng [sm=groupwave.gif]
The ecu is located under the driver seat, the window to read the code is facing the rear so you have to slide the seat all the way forward ,
the # of blinking is the same # as the code, there is no long blink and short blinks,, so whatever it blinks that's the code, there is a 2 seconds pause between 1 code and the next, so make sure to have it repeat at least 2-3 times to make sure that there is only one code or more than 1
Summerskiss2002
12-04-2005 10:14 PM
