check light help
Old 08-19-2007, 08:46 PM
pacifica_kid
Default check light help
my cars was running fine tillyesterday i did the self check it gave me 4 slow 3 fast so thats meens 43 right every where i looked at its says fuel supply..did a fuel fitter today.still the same code? but my cat/// stinks like rotton eggs.. help me please thanks////
[IMG]local://upfiles/3398/B078B628D856466CB2CBA7D05F97A7BE.jpg[/IMG]
Old 08-19-2007, 09:11 PM
Default RE: check light help
Check your fuel pressure regulator vacuum reference line by removing and sniffing. If you get a strong smell of gas, then fuel supply may be the problem. The diaphragm in the fuel pressure regulator has ruptured and raw unmetered gas is being pulled through the vacuum reference line into the throttle body. This would cause excess fuel and possibly the rotten egg smell.
Code 43 can be fuel supply or O2 sensor circuit. Have you checked that O2 sensor is cycling hi-to-lo voltage 0.1-0.9 v, w/ a mean of 0.45V. You need a high impedance (1 megaohm or higher) volt-ohm-meter (VOM) to measure voltage on a live circuit. A replacement O2 sensor can be purchased inexpensively (ebay or local auto parts), and if it's never been replaced or is old, this is a distinct possibility. The rotten egg smell can be associated w/ excess fuel supply, which might be caused by a failed O2 sensor.
Also add your car year and trim level to your signature line so it will be obvious.
Old 08-24-2007, 09:41 PM
pacifica_kid
it was the o/2 senser took my cat off found part of o2 senser in it runs fine now thinks for help//
Mott
03-15-2016 11:25 AM
ddold@gkschools.org
01-29-2008 03:35 PM
62maxx
10-26-2006 01:04 PM
hotrod01
11-11-2005 01:28 AM
Quick Reply: check light help
